Author Topic: Suggestion: bulk change filename for code gen  (Read 7554 times)
andymc73
  • Make the computer work for you
« on: February 18, 2007, 04:15:55 pm »
Hi all,
I often need to generate IDL code (using the MDG Corba plugin).
When using the Auto Generate files checkbox, each and every class, interface and enumeration in a package goes into its own IDL file, even though they all share the same Corba module in the generated code. However I would like to send all generated IDL for a package into a single .idl file.
My existing workaround:
If I don't check "Auto Generate", I am prompted one at a time, for every one of these elements for a target file, at which point I can select the same filename and end up with all elements in the one file.
However this is very laborious when there are a lot of elements, and a royal ??? :-( if I want to change a filename.
Given the dialog box appears to be common for all languages I would assume the problem exists for C++ although often good coding practice would suggest that generally there would be a separate H file per class.
I note that when generating SQL DDL, however, I have the option to send all tables to one file.
I would like to see the ability to optionally (not by default) see all generated code go to the same file, without having to manually set the file one at a time after resetting code generation settings for the package.
(The equivalent setting for DDL generation is the radio button "Single File")
--Andrew
andymc73
Re: Suggestion: bulk change filename for code gen
« Reply #1 on: May 09, 2007, 05:37:56 pm »
Does anyone have an opinion on this or is it just me? ??? :-[
jeshaw2
« Reply #2 on: May 12, 2007, 12:35:58 pm »
I think the answer is No.
Since I don't use Corba, I don't have an opinion, and assuming your request is consistent with good software development, I think the request is reasonable; therefor, I don't think it is just you.
Sorry I could not help with your initial question.
« Reply #3 on: May 12, 2007, 01:36:15 pm »
I'm with Jim...
Although we do use IDL, the current functionality is OK with us.  But that's not the point.  If the language allows it, then EA should support it.
I definitely have multiple C# classes in a single file.
« Reply #4 on: May 12, 2007, 02:28:27 pm »
Same thoughts here. I don't use IDL, although some associates along the way have. Regardless of target, it would be nice to have the option of consolidating generation if the platform supports it.
andymc73
« Reply #5 on: May 14, 2007, 02:54:08 pm »
Thanks all,
Ill raise a bug with registered support.
--Andrew
