Author Topic: bulk import of pictures  (Read 7686 times)
JohnDoe
  • EA rocks !
« on: June 05, 2007, 02:42:22 am »
I would like to import an amount of pictures into my EA picture library. Instead of klicking "Add new" (Settings->Images) for every single picture, I would like to import a complete folder with a number of pictures. Is there an option to achieve this bulk picture import or should this go here as a feature request ?
Regards
Bernd
« Last Edit: June 05, 2007, 02:42:30 am by BerndWill »
Re: bulk import of pictures
« Reply #1 on: June 05, 2007, 03:01:23 am »
Bernd,
Add my vote here.
I don't think there is such a method - although I could be wrong here.
If not, I think this would make a great feature, and is likely not a major overhaul.
« Reply #2 on: June 05, 2007, 05:12:02 am »
My vote also, Bernd...
Graham_Moir
« Reply #3 on: June 08, 2007, 12:28:16 am »
And my vote too,  although the xml image library provided by Sparx which can be found at
http://www.sparxsystems.com.au/resources/image_library.html
does show there is a way to load in a set of images - just doesn't directly support picking up all files in a folder.
« Reply #4 on: June 08, 2007, 01:25:12 am »
Nor do I think there is a reliable (i.e. supported by Sparx rather than coincidentally workable) means of generating such an XML file. Perhaps this too could be a useful feature.
« Reply #5 on: June 11, 2007, 01:27:44 pm »
That file can be generated in a way supported by sparx by using the Tools | Export Reference Data.
Of course that isn't going to help you as you first need to import it into EA to use that method.
« Reply #6 on: June 12, 2007, 04:31:58 am »
Thanks Simon,
That solves part of the problem. At least we know the process is repeatable once we 'prime the pump.'
Could you at least publish the specifications? Perhaps - at our own risk of course - we could come up with something for the first import, then publish and maintain it on the Wiki.
JohnDoe
  • EA rocks !
« Reply #7 on: June 19, 2007, 11:43:10 pm »
The XML file has two major components:
a) a XML structrue, which is readable and can be generated
b) a Base64 encoded object
I just created a new MDB and made a link to table t_image of my EA project file. Then I have created a form, which is based on the t_image table. But there are no visible pictures inside, though the table is filled with "large binary objects". What is the format of the pictures that EA displays ?
Regards
Bernd
« Last Edit: June 20, 2007, 12:01:58 am by BerndWill »
