Author Topic: Attach note to message on Sequence Diagram  (Read 5995 times)
d_p_robinson
« on: July 04, 2007, 05:04:45 am »
I'd like to be able to attach a note to a message on a sequence diagram to provide commentary on the message. At the moment I can only attach a note to the (invisible) border of the element's lifeline which looks peculiar or leave the note floating unattached.
:o Dare I say it: Rose does this and I rather miss this feature (and the other UI features that make Rose a more pleasant place to work :D)
David Robinson
Re: Attach note to message on Sequence Diagram
« Reply #1 on: July 04, 2007, 01:48:59 pm »
You can right-click the message and select "Attach Note or Constraint". In EA 7.0 you will also be able to right-click a note and "Set Attached Links" (in EA 6.5 this is only available for notes that are already attached to at least one link).
d_p_robinson
« Reply #2 on: July 04, 2007, 10:48:45 pm »
Found it, thanks. Would it be possible for this to be available as a quick link?
David Robinson
