Author Topic: BUG: stereotypes on aggregation/composition ends  (Read 10101 times)
SF_lt
  • The Truth Is Out There
« on: April 20, 2007, 03:05:41 am »
stereotypes on aggregation/composition ends aren't shown - it's not an issue with th association, so this definitely is the BUG
workaround: draw association, then set one of it's end for share aggregation :-/
Also, stereotype position/alignment management for the association end is f...ed up - should I post screenshot? really not good for me, any other oppinions?
Registered as bug requesting to fix for the next build  ;)
« Last Edit: April 20, 2007, 03:27:58 am by SF_lt »
registertm everything to SparX
jkorman
Re: BUG: stereotypes on aggregation/composition en
« Reply #1 on: April 20, 2007, 05:12:45 am »
I'm not sure what it is you're trying to do. I'm using EA build 805 and can get stereotypes on all association ends "shared" or otherwise.
I think I agree I'd like the role and stereotype to be separate, movable items.
Jim
SF_lt
« Reply #2 on: April 20, 2007, 06:16:51 am »
Jim, you haven't read carefully ;D - problem is with the aggregations/compositions. Workaround is to draw association instead of aggregation/composition and to set aggregation kind for the end.
« Reply #3 on: April 20, 2007, 07:11:36 am »
But see the various threads Paolo (et al) have started on the subject of how EA handles Associations.
[One major point being that there are two way to get there, and they do not produce the same results in the internal model structure. This could bring you grief in future if you are not fully aware of the issues.]
jkorman
« Reply #4 on: April 20, 2007, 07:24:21 am »
Sorry. I've been not using Aggregate/Compose from the tool bar for so long, I'd forgotten some of the weirdness.
Jim
SF_lt
« Reply #5 on: July 16, 2007, 03:17:59 am »
bug isn't fixed in EA 7.0  :-/
