Author Topic: Move dependencies between interfaces  (Read 5738 times)
« on: June 20, 2007, 11:25:38 pm »
Hi there,
(this might be a 7.0 issue) when I try to arrange exposed interfaces on a component (with MANY) interfaces then I find it hard to select a single interface. Often EA prefers to select a crossing dependency. Then I drag the dependency instead of the interface. Now the bad thing! Eventually the dependency snaps into another interface :o I messed up quite some dependencies before I was aware of that. So be careful! Changing the connection of a dependency definitely need a special action (shift click). I will report that as bug.
sargasso
Re: Move dependencies between interfaces
« Reply #1 on: June 25, 2007, 11:54:56 pm »
TK,
AFAIK this has been a problem since the year dot.  The only quick way I've found around it is to use the zoom/pan tool to bring the node up to 300%+, select the dingo you want and zoom back out
hth
bruce
p.s. still as busy as a pup who's just discovered his tail.
« Reply #2 on: June 26, 2007, 10:52:59 am »
Funny that I never stumbled over this. I will report a bug - as soon as I'm no longer busy. So no hurry - I now have my way to manage the interfaces with quite some help of add-ins.
« Reply #3 on: July 20, 2007, 05:42:50 am »
Following I post my reply to Sparx replx. What's your opinion?
Hi Nicholas,
if this is a feature then it is definitely a drawback. It introduces the described side effects which are definitely unwanted. And again it makes the UI more complicated as the shift-click is expected to do exactly that connector move. I will post your reply and my comments on the board to see what the other users think of it.
Cheers, Thomas
Am 20.07.2007 um 01:14 schrieb sparxsupport:
Hello Thomas
Dragging connector ends to other elements is not a bug, this is an added
feature for version 7.0.
Best Regards,
Nicholas Zounis
Sparx Systems Pty Ltd
http://www.sparxsystems.com.au
