Author Topic: Minor bugs and feature requests (Sequence diagram)  (Read 4342 times)
nogo
« on: July 24, 2007, 02:05:08 am »
All,
Maybe as a newbie I have missed some configurable EA parameters (in this case I'd warmly acknowledge pointers on how to fix any of the items below) but it rather seems to me that there are some minor gotchas in EA's (6.5) behavior when editing sequence diagrams, mostly related to fragments (specifically loop). Did not test it with EA 7.0 but none of the items below is listed on the fixed-issue list. Positive aspect: the behavior is reproducible. ;)
1. When selecting a bigger font for objects (e.g. 14), the loop condition text (in square brackets) does not preserve the distance to the loop fragment name tab (i.e., the condition text's upper part overlaps the loop tab in the upper left fragment corner). Bugfix required, as feature request you could file a user-configurable font size and gap for fragment conditions.
2. (Loop?) fragments can not be moved by the Z-ordering, i.e., they stay on top, regardless of the Z order. This is annoying when selecting a solid color fill for the loop fragment as this color covers the object lifelines. Imho the  missing Z-ordering makes solid color fill for fragments a useless feature. Bugfix: Enable Z-ordering for fragments.
Feature request: I'd love to have transparent colors and/or fill patterns for the loop fragment.
3. When applying a solid color fill to a loop fragment and afterwards reverting to the default color fill, all message labels within this fragment preserve the initially set color fill as background font color. This is valid for diagram output using Diagram->SaveToFile, Copy to clipboard, Print Preview, etc.
Closing EA and re-starting fixes the problem, alternatively  you can apply white as solid fill for the loop fragment and afterwards revert to default color.
4. Manual resize of sequence message labels to prevent a line-break is not preserved when the label is formatted as bold (when using message sequence numbering). Re-load of the diagram always inserts the same line break after the sequence number on longer message names.
Also when changing the diagram/object font size on an existing diagram EA splits many labels onto two lines - it inserts a line break after the message sequence number.
Feature request: I'd really love a global check-box in the sequence diagram options to enable or disable EA inserting line-breaks into message labels (i.e.: Automatically break labels: Yes or No).
Any hints on how to fix/work-around the problems reported above are also warmly welcome.
best regards
Joachim
Re: Minor bugs and feature requests (Sequence diag
« Reply #1 on: July 24, 2007, 02:14:50 am »
Thanks Joachim,
You've nicely covered these, and isolated the specific faults very well. Sequence diagrams - at least before 7.0, I've not checked them there either - were 'orphans' in EA. They are built and handled differently down in the EA engine.
Have you reported these directly to Sparx? If not, please do so. You can reach the correct form by following the Support link at the top of any forum page, then clicking Bug Report in the left side menu. Or from the EA main menu via Help | On-line Resources | Bug Report Page.
You should paste in a link to this thread so Sparx will know where to read comments or post replies to the community.
Also, if you get feedback from Sparx, please highlight it here.
nogo
« Reply #2 on: July 24, 2007, 02:32:17 am »
Thanks for the hint - I just followed your advice and submitted the bug to the EA support including the link to this thread.
Joachim
« Reply #3 on: July 24, 2007, 02:34:14 am »
Good stuff Joachim,
We'll be watching for updates.
