Author Topic: Possible Bug in Activity Diagram Version 7.0  (Read 4608 times)
philchudley
« on: July 25, 2007, 02:00:31 am »
Hi All
When an action pin is added to an action, it displays as normal, but if the action pin is selected and moved around the edge of the action, the action pin dissappears!
Any connections to the action pin, appear to be connected to the action pin, but as the pin is no longer visible they end in "mid-air"
Advice?
Models are great!
Re: Possible Bug in Activity Diagram Version 7.0
« Reply #1 on: July 25, 2007, 04:04:35 am »
Hi Phil,
First, ensure that you are running the most current build (814 at this time).
If the problem is in build 814, submit a bug report directly to Sparx. You can do this by following the Support link at the top of the forum page, then clicking Bug Report in the left side menu.
You can also do this from the EA main menu via Help | On-line Resources | Bug Report Page.
If you hear back from Sparx please let us know the solution or anticipated time frame.
« Reply #2 on: July 25, 2007, 01:04:54 pm »
We currently have someone working on this issue.
