Author Topic: RTF generation - Connector source / target element  (Read 6986 times)
Dave_Bullet
« on: July 29, 2007, 03:19:30 pm »
I need to be able to list all the connectors under my diagrams in my RTF documents and be able to include the source / target element names for each.
Currently - you can only include source / target element names for a connector, when you list the element at a package level (not within the diagram section)
Sparx - can you please extend the connector under the diagram section in the RTF generator to be able to include source / target element information (to be consistent with the connector setting already under the element section?).
David.
Re: RTF generation - Connector source / target ele
« Reply #1 on: July 30, 2007, 02:01:24 am »
That's a very good idea David. And also one of those things that escapes notice (at least mine) until you run into it.
There is the possibility of listing a connector several times - in cases where it is shown on several diagrams - but handling these situations should be no more onerous than those where an element appears several times.
I am also assuming that you mean explicitly those connectors that appear on a diagram. This would exclude any connectors that are not visible on the (entire) for any reason.
