Author Topic: EABase_JET4.eap  (Read 6720 times)
eberline
EABase_JET4.eap
« on: January 23, 2006, 01:10:53 pm »
From another thread in the General forum,
Re: new project in ea 6.1
You can no longer select which file will be the used as the base model for new projects - it is now always EABase.eap (found in the EA dir).  You can replace this file with your preferred base model.
Ash
It would be helpful if EABase_JET4.eap were included in the EA full installation package, and selecting
   Tools -> Options -> General -> Use JET 4.0
would cause new models to start from EABase_JET4.eap instead of EABase.eap.
Re: EABase_JET4.eap
« Reply #1 on: August 15, 2007, 02:12:10 pm »
Absolutely!
Scott's spot on here...  Actually, given the number of years since Jet3.5 was the "default" MS Access technology, the default should be Jet4 and 3.5 be supplied as an alternative.
Re: EABase_JET4.eap
« Reply #2 on: August 15, 2007, 02:34:52 pm »
Oh yes!
More so, since Jet 3.51 is not always present on systems now, nor does it seem to properly set up in some cases - there are ample examples in posts over the past year or so.
Jet 3.51 dates back 10+ years, which exceeds even the extended support periods for MS technologies.
Just my 0.02 CAD on the subject.
