Author Topic: HTMLWidget in EA  (Read 8569 times)
angel-o-sphere
HTMLWidget in EA
« on: August 16, 2007, 05:10:14 am »
another "wiered" idea: would it probably possible via the Add In API to have a HTML widget in the area where you have the properties/pan&zoom views?
Background is: I like to keep stuff like UC Texts either in a Wiki or in an Eclipse project.
It would be cool if the EA could display a web page that is referenced via an automatism, or via a tagged value, when a node is selected.
Example:
I have a use case "Create Customer" and some where is configured that my URL for Use Case Texts is: http://intern.visualsphere.com/project_bla/usecases.jsp?{name of usecase}
Or I configure:
http://public.visualsphere.com/project_bla/{name of usecase}.html
There only needs to be a string which uses a parameter substitution schema like the Tools under the Tools menu in EA.
Angelo
Re: HTMLWidget in EA
« Reply #1 on: August 16, 2007, 05:34:17 am »
Angelo,
I'm fairly sure you could do this via the API. You would probably have to write this as an add-in (rather than an external automation program).
The API allows you to design and install your own windows, which can act the same way as other 'panels' do in EA.
angel-o-sphere
« Reply #2 on: August 17, 2007, 05:20:12 am »
Is there a market palce somewhere so I can hire a poor sole to do that ;D
As I noted in an other psot: I have no clue about OLE/COM/.Net  in that depth and no intention to fiddel with MS technologies.
Angelo
« Reply #3 on: August 20, 2007, 11:14:31 am »
Half a year ago I would have had the time. But now...
I guess this place is a good starting point. Else try XING or Gulp.
