Author Topic: Requirement Report with tagged values  (Read 4097 times)
tatiane
« on: January 27, 2010, 10:12:15 pm »
does anyone knows how to generate a report with requirement template and show the tagged values of the requirement?
I use the tagged value to put extra information about my requirement and i need to generate the report with them to have the requirements aproved ?
Sorry for my english, i´m brazilian  8-)
Best Regards
Tatiane
Chris Tatem
Re: Requirement Report with tagged values
« Reply #1 on: February 03, 2010, 06:45:56 am »
You will have to create your own template from the standard Requirements one, from the generate RTF dialog - Create New Template, copy from Requirements.  In the Template editor, 2 chocies - 1) check (on the left) the Tagged Values option under Element, then in the document, right click to add tag name and/or tag value.  Or, 2) in the templete, right click and select ValueOf - it should prompt you for the name of the tagged element and it should put the value of that tag in the document.
(I don't have EA open this minute, so these are from memory)
chris
tatiane
« Reply #2 on: February 04, 2010, 02:40:29 am »
thanks chris i will try  ;)
tatiane
« Reply #3 on: February 20, 2010, 05:21:58 am »
Chris,
The tip "ValueOf"  was the best choice for my question. it worked!
Thanks a lot!!! 8-)
