Author Topic: Importing BPMN Images  (Read 5686 times)
kitab2007
« on: October 09, 2007, 08:13:26 am »
Hi All
How can we insert/generate BPMN images in report.
Thanks in advance
Re: Importing BPMN Images
« Reply #1 on: October 09, 2007, 09:09:59 am »
If you mean an image of a BPMN diagram, absolutely. Just like any other diagram, just use the control-b shortcut, which will paste the diagram to the clipboard. Then use the paste command of your target application to insert the image.
For example, using MS Word you'd select your diagram in EA, press control-b, switch to the spot in Word where you want the diagram and press control-v.
There are several settings that will affect how this works, although the defaults usually work well. You can find these in the following places:
  • The Tools | Options main dialog; at the top right you'll see the default format EA will use.
  • The Tools | Options | Diagram page contains settings for the maximum diagram memory (which might not affect paste operations), opaque diagram labels, and diagram frames.
HTH, David
kitab2007
« Reply #2 on: October 09, 2007, 01:47:03 pm »
Hi David
Thanks for your help.
