Author Topic: Port+Interface should allow choosing operation  (Read 36529 times)
MrDX
« on: October 21, 2007, 12:44:24 am »
it's possible to set a interface to a port (with 'Advanced'->'Set property type'). After adding an object of such a component (into a sequence diagram) and adding a message to a part, it's not possible to select a available message from a list.
It would be more confortable to provide this feature, like it's supported for 'normal' classes with operations  :)
Davide F
Re: Port+Interface should allow choosing operation
« Reply #1 on: September 08, 2023, 04:21:19 pm »
Hi are there news concerning this problem?
I'm using EA 16.1 and the problem occurs, in older versions this was possible.
The only way to let the operations be seen is to drag a link of the component (and not a lifeline). But I guess this is not really UML compliant, isn't it?
