Author Topic: Newbie Questions  (Read 6587 times)
edusem
Newbie Questions
« on: October 16, 2007, 12:49:27 pm »
I have a few questions regarding EA and hopefully somebody already has this figured out:
1) How can I specify the location of a particular element, as well as its size/width from a menu or properties option instead of having to manually drag it to a particular location? As an analogy, for example, if you are creating a box in Word, you can specify its location from the top or bottom of the page and can specify its width/height from a menu option.
2) How can I copy/paste single elements so that I don't have to recreate them every time I need a new element?
3) When I was working on the activity diagram in Exercise 2, I lost my label, i.e., the item in brackets: [correct], [trivial problems], etc. and could not find a way to get it back (I tried the hide/show label options but it didn't work). I was wondering if anybody knows how to do this (as well as copying a label and changing its name - again the copy/paste question).
I understand that EA is more than a drawing program and that the elements have links, properties, etc. that makes them more complex than just graphics on the page. However, there should be a way to take an existing element, copy it and change its properties, links, etc. manually very much like the ControlFlow activity relationship (the "arrows") where you can select the Source/Target, line style, etc. I tried the help on EA but could not find an answer. Any suggestions?
Thanks.
Re: Newbie Questions
« Reply #1 on: October 16, 2007, 11:25:34 pm »
1) Only using Automation (add-ins). There is no GUI to do that. I think it could be helpful and worth while a feature request.
2) You can use CTRL-click to re-create the last element
rest) no idea
peter.zrnko
« Reply #2 on: October 19, 2007, 01:10:27 pm »
2) see help on copy
Peter
dbax
  • One EA To Rule Them All
« Reply #3 on: October 22, 2007, 07:51:34 am »
3) You may have tried this but it doesn't hurt to ask: Did you try Set Label Visibility and play with options there?
oscarsnr
  • Be The Boy
« Reply #4 on: October 23, 2007, 01:41:58 pm »
If you're feeling brave, you can go into the EA database and configure the appearance of objects on a diagram there. Try having a play with the 'Rect...' values in the t_diagramobjects table. (You'll have to reload the model in EA to see the results of your database changes).
