Author Topic: Source Directories and UML Packages  (Read 4027 times)
« on: October 03, 2006, 08:13:17 pm »
In another topic (Packages, Namespaces & groupings I propose that one way out of the UML package being a namespace and not a folder is to provide "Grouping Only" packages below (and above) the Namespace packages.
With platform specific languages that are namespace based (such as C++, C# etc), this means that there is often an enclosing package.
At present, when you select such a package in the browser and request to Import Source Directory, the dialog retains a "sticky" value form the last time it was run.
My suggestion is to utilise the Filename attribute of the enclosing package.  If there is a value there that parses to a directory, then Import Source Directory would take the value it found there as the Root Directory for the import.  This could be controlled by a check box on the dialog
  • Take Root Directory from package Filename[/b][/font].
    Thoughts?  Votes?
    [size=0]©2006 Paolo Cantoni, -Semantica-[/size]
Re: Source Directories and UML Packages
« Reply #1 on: November 05, 2007, 11:41:36 pm »
[size=13]Packages, Namespaces & groupings[/size] has additional, related information.
« Reply #2 on: November 06, 2007, 03:53:18 am »
Yes! Certainly add my vote.
This is YA good implementation effect of the Grouping Package concept.
