Author Topic: Parts and Ports  (Read 3876 times)
Mr. Sanders
  • Dilbert for president
Parts and Ports
« on: November 06, 2007, 07:34:33 am »
when drag'n'drop classes to components you can define that the class is part, port or neither of them.
When you select Port or Part you have to give them a name
and the default proposal that EA gives is Port  or Part.
It would be very helpful if the name would be the same as the class I drop.
In most cases this is good enough.
In the way EA implements it, you always have to change that default, because Port and Part explains nothing in the diagram.
If I don't want to have it as a port or part,
I would expect that the dropped class is shown in the project explorer as a sub element of the component, but not as a copy, rather than as a reference to the original class.
Thus I would circumvent the port/part level, which we don't find necessary. It would be very nice, if the class references are directly shown below the component node in the project browser.
Michael
« Last Edit: November 06, 2007, 07:37:00 am by mizd »
