Author Topic: API support for Export/Import Reference Data  (Read 22168 times)
« on: April 23, 2007, 02:12:59 am »
There are methods for exporting and importing package XMI, as well as transformations and imports (forward and reverse engineering), but reference data seems to be unsupported.
Methods for doing this - probably via the Repository object - would be welcome.
Re: API support for Export/Import Reference Data
« Reply #1 on: April 23, 2007, 02:23:20 am »
Seconded (and Thirded)
(vote early and often!  ;D)
fr3sh
  • drop it like it's hot baby
« Reply #2 on: April 23, 2007, 02:41:50 am »
vote... i need it  :(
salayande
  • I love YaBB 1 Gold!
« Reply #3 on: April 24, 2007, 10:40:46 am »
API support for reference data is valuable. I support this.
pmullin
« Reply #4 on: November 21, 2007, 08:01:14 am »
I vote for this one too.
Disseminating updated reference data to multiple users is a real pain.  There does not appear to be any sensible way to do this when using private EAP files that are synced via version control.   Ideally, this data should be part of the root package, so that it can be included in VC updates.   Short of this, writing an add-in to do the import would be reasonable, if the APIs were available.
« Reply #5 on: November 21, 2007, 08:10:36 am »
Me too!
« Reply #6 on: November 21, 2007, 01:46:24 pm »
Unsupported, undocumented, 7.0.818 and later:
Repository.CustomCommand("Repository", "ImportRefData", sXML)
or
Repository.CustomCommand("Repository", "ImportRefData", sFilename)
:-X
« Reply #7 on: November 21, 2007, 04:04:38 pm »
or
 :-X
But it is a beginning Neil.
Any way to filter what you export and import? Or do we just end up dumping everything, and replacing everything on the other side?
« Reply #8 on: November 21, 2007, 08:53:39 pm »
Just to be clear, import is additive.  If the item already exists, then it's updated.  If its new, it's added.  If it was deleted - too bad...  It's still in the target.
There is no "true" replace this set with that set - as with package import...
peter.zrnko
« Reply #9 on: November 22, 2007, 12:00:45 am »
And it will be very nice to Version control Reference data from EA.
It has a
 big   + nice control in the same way as packages
 small - necessity to check out Reference data before modifying them.
Peter
« Reply #10 on: November 22, 2007, 04:41:20 am »
So, a desirable option would be to replace or refresh the settings. Of course this should be a parameter in the API call as well.
