Author Topic: Element Browser - Going to properties dialogue  (Read 5906 times)
Graham_Moir
« on: January 28, 2008, 02:58:51 am »
Double clicking on an aspect of an element in the element browser (e.g. attributes) simply takes you to the standard default properties pane - it would be much better if this opened but you were taken to the relevant tab/section of the properties based on what you clicked on in the first place.
Martin Terreni
  • Sorry, I can't write
Re: Element Browser - Going to properties dialogue
« Reply #1 on: January 28, 2008, 05:55:04 am »
I think I would need a further explanation.
What tab would you expectto be default for each type of element? What context will "defaultize" the tabs?
Recursion definition:
Graham_Moir
« Reply #2 on: January 28, 2008, 06:35:18 am »
If you use the element browser (found under "More windows" on the "View" menu - not the project browser),  you get a tree like structure for a single element when the element is selected.   However if I then double click on say one of the defined constraints, the standard properties dialogue box appears with you positioned on the "general" tab.  As EA knows I'm interested in a specific constraint it would be much better to take me to that constraint on the "Constraints" tab.
« Last Edit: January 28, 2008, 08:59:25 am by Graham_Moir »
Martin Terreni
« Reply #3 on: January 28, 2008, 08:29:50 am »
Well.....EAUI?
