Author Topic: Numbering in RTF Notes EA 7.1  (Read 3792 times)
philchudley
« on: February 08, 2008, 02:41:09 am »
In the new RTF enabled notes feature, if a numbered list is used, then it cannot be interrupted with non-numbered lines and then the list continued. For example, here is a simple Use Case scenario using the numbered list. This scenario (copied from EA 7.1) indicates where alternate paths may exist:
1)The use case begins when the Customer adds an item to the cart
2)[ALTERNATE] Create Cart
3)[DATA] productCode
4)[DATA] quanity
5)System creates an Item using the product code and quantity
6)System checks the quanity on hand using the product code and quantity
7)System adds the item to the cart
8)[ALTERNATE] Insufficient stock
9)Use Case ends
If I remove the line numbering from the lines with [ALTERNATE] and [DATA], the result is
[DATA] productCode
[DATA] quanity
1)System creates an Item using the product code and quantity
2)System checks the quanity on hand using the product code and quantity
3)System adds the item to the cart
1)Use Case ends
What I would like to happen is:
[DATA] productCode
[DATA] quanity
2)System creates an Item using the product code and quantity
3)System checks the quanity on hand using the product code and quantity
4)System adds the item to the cart
5)Use Case ends
That is "Continue Numbering"
Models are great!
Re: Numbering in RTF Notes EA 7.1
« Reply #1 on: February 08, 2008, 03:29:48 am »
So, for now you might have to extract the included use case to an included use case...
