Author Topic: Deep Copy of Packages [SOLVED]  (Read 6298 times)
mkeuschn
« on: May 06, 2008, 12:50:23 am »
Is it possible to copy an entire package with all its child elements (deep copy), or can I do it with some export, import actions?
Would be a nice feature for EA 7.2 if it is not possible to do such a copy  ;).
best regards,
mkeuschn
« Last Edit: May 09, 2008, 12:08:45 am by mkeuschn »
Re: Deep Copy of Packages
« Reply #1 on: May 06, 2008, 01:23:41 am »
Export to XMI and import again.
Remember that external references - to elements outside of the package tree involved - can produce problems if you don't import to the same project.
Also, read up on the Strip GUIDs option and when you should use it.
mkeuschn
« Reply #2 on: May 09, 2008, 12:08:07 am »
Thank you for your response.
I have found a way to get a copy. The first step is to export the model (you have to take the package after the root element) and call it ucm.xml. When you now create a new Use Case Model with the wizard, the wizard take the formaly created ucm.xml file to create the structure of the new Use Case Model.
best regards,
mkeuschn
Re: Deep Copy of Packages [SOLVED]
« Reply #3 on: May 09, 2008, 08:58:12 am »
Just so you know.  If you want to create a copy without overriding something from the model wizard you can export it and re-import it with strip guids on as David suggested above.  This will acheive the same effect.
Alternatively you could distribute it as a separate file with an MDG technology and have a custom entry in the wizard.
