Author Topic: TOGAF Extension Improvements  (Read 4717 times)
andersd7
« on: July 10, 2008, 11:33:59 am »
Using UML to describe Enterprise Architectures is not easy.  I was hoping the TOGAF extension would help provide guidance on being able to simplify this task.  Your product does provide a head start, however I believe the following suggestions should be considered in a future release.
  • TOGAF elements should be included in a UML Profile so that the elements can be extended if required
  • Extend the number/variety of reference or example models to help link TOGAF concepts and how they have been applied in UML.  eg the Enterprise Continuum
  • Provide a model of how each of the TOGAF elements relate to one another.  I get the impression when I look at the different diagram types and the associated toolbox, there has been no attempt to provide linkage.  eg I was modelling an application which is used by the business and wasn't sure if it was solutions building block, an architecture building block, an asset, a system, base line architecture, target architecture.  It could well be any number of these depending upon the view point, but to achieve this I would need to treat them as separate elements.
