Author Topic: Can't choose same file for VC  (Read 6280 times)
Martin Terreni
  • Sorry, I can't write
« on: July 29, 2008, 10:54:25 pm »
After entering a package to VC, if I want to, lets say, import a newer version from XMI which was not under VC, I can import it without striping GUID and it works fine.
the problem is that I loose the VC configuration, and the bigger problem is that I can choose the same name I had when reentering it.
Why do i not have an option to reuse the same package??
With this philosofy you shouldn't let me override an EAP file...
It happens many times and it means iwe always have to delete it from VC and recreate.
Pleaseadd this option.
Recursion definition:
