Author Topic: Use Case.pdf  (Read 4099 times)
marcelloh
Use Case.pdf
« on: August 05, 2008, 05:24:58 pm »
http://www.sparxsystems.com/bin/Use%20Case.pdf
This is a nice report, and I want to generate this kind of reporting.
Which template can I use to do this?
Dermot
Re: Use Case.pdf
« Reply #1 on: August 07, 2008, 04:40:27 pm »
I underastand that this report was generated using the Automation Interface to Word, however the RTF report generator (F8) has a very similar template {use case template} - I would suggest you create a copy of this and modify it to suit your needs.
