Author Topic: Some needs in documentation generation  (Read 3992 times)
fbp
« on: September 18, 2008, 12:15:27 am »
Here are some requirements i think necessary to improve documentation generation, some of them are from SODA
- First of all, the hability to add "if...then...else" statement in documentation generation. Thus it would be possible to add relevant elements to thegenerated parts
- hability to follow "relationship": for example,the hability to find all object which are aggregating (or agregate this element). This is a real problem in usecase report, when i whant to know whitch arctor is linked to my useCase...
- more flexible recursivity in package : i maybe need only 1 level under, not all levels... i need flexibility in titles numbering too, the level are not corresponding to model levels...
- hability to generate a more clean RTF. Here the image are well embended for microsoft ... not for openOffice. (in word, i need to show field (alt+f9), select all (ctrl+a), remplace field by their value (ctrl+f9) and the save if i want to open it with a non-microsoft editor). Other point, the used styles are not readable with a non-microsoft editor.
- hability to generate a PDF report : if i do a model centric approach, i want my document read only... that ask a goog documentation generation ;-)
Open to work on documentation generation if needed...
Fred
marcel_str
Re: Some needs in documentation generation
« Reply #1 on: September 18, 2008, 02:38:44 am »
I think you're right that document generation can be boosted with some additional or more flexible functionality.
Though, I think some subjects in your post are allready covered.
If I'm right you should be able to do something like this with an element called: "model document". This element has a tagged value called: "Searchname" and "Searchvalue". I'm still exploring this functionality myself as well, but it sounds like a possible match for your issue.
Recursivity in packages is not really flexible, though you can deside not to generate RTF for child packages or child elements. But I guess that's where flexibility stops as well.
I don't actually understand what you mean by synchronising the title numbers to level numbers. Why would you want to synchronise these?
« Last Edit: September 18, 2008, 02:42:09 am by marcelstr »
