Author Topic: DB Schema Import - SQL Server 2000/2005  (Read 4908 times)
gonzalo.vinas
« on: September 19, 2008, 01:52:32 am »
Hi there all! - I would like to suggest firstly that the DB Schema Import feature of the 7.1.xx release would be enhanced in such a way that Triggers can be imported into the EA model as first-class citizens and have linked their dependency relations with DB objects suchs tables, views, etc.
And also it would be nice to have the .Net assemblies imported too like User Defined Types / Functions.
What do you think ?
Cheers,
Gonzalo Viñas
salayande
  • I love YaBB 1 Gold!
Re: DB Schema Import - SQL Server 2000/2005
« Reply #1 on: October 07, 2008, 05:10:50 am »
Pls kindly raise a formal request on the support pages
kind regards
Segun
« Reply #2 on: October 07, 2008, 09:02:28 am »
Hi Gonzalo,
I agree with Segun, please submit a request! This would be a powerful feature.
At first glance I thought it would have to wait until EA made considerable progress at code engineering for stored procedures. Then I got to thinking about it and realized this might be closer at hand. That said...
Perhaps you could work around this manually. Try importing the .Net assemblies via the Import Binary Module function. If this works - I think it should but I have not tried this with SQL Server assemblies, so I am being cautious in my assumptions - then see if you can manually set up something analogous to the way EA represents stored procedures.
You would have to use a different stereotype - I think it would be best to something new - to identify the assembly. Perhaps you might even do something along the lines of a container element for multiple classes within the assembly.
This would not work for forward engineering (generating SQL Server assemblies) but you might be able to manipulate the classes and use them to generate a new .Net project (or parts thereof), from which SQL Server assemblies could be built. Perhaps you could do this with an EA transformation script. Perhaps you could even build the data model containers mentioned above this way, but my guess is that lies beyond what transformation scripts will do. [But EA scripts are powerful enough to succeed in unexpected ways, so don't be shy about trying it]
If you get anything like (any of) this working (or even try it out) please post back and let us know what happens.
[edit]PS: Perhaps something along these lines - with various differences as appropriate to the different environment - might be applicable to the Oracle plumbing for .Net (which is also emerging as a very powerful development paradigm). I don't use it enough - at least not since Oracle 10i first appeared, and Oracle has really moved the environment forward since then - to be in a position to try. If anyone can shed light on this area, please start a thread and tell the EA community.[/edit]
