Author Topic: Right click multiple elements - Z-order  (Read 6038 times)
Dave_Bullet
« on: October 20, 2008, 06:07:24 am »
I should be able to select multiple elements then right click and either send them all to the back, bring them all forward, or move them back or forward relatively.
There are a lot more common operations between elements, that Sparx could implement on the righ click menu based on the UML classification hierarchy, plus building a hierarchy of inheritable GUI operations, compatible between like elements.  I know this has been requested before.
David.
Re: Right click multiple elements - Z-order
« Reply #1 on: October 20, 2008, 08:02:41 am »
Without discounting your request, perhaps even adding weight to it...
The commands in the main menu for z-order can be executed with multi-select.  They can even be docked as a toolbar.
Dave_Bullet
« Reply #2 on: October 21, 2008, 08:19:27 am »
Thanks Simon for that ;)
I'm just a lazy right mouse click kind of guy.  I should have checked and don't mind using the main menu.
Cheers,
Dave.
