Author Topic: Access database ODBC direct forward engineering  (Read 6794 times)
salayande
  • I love YaBB 1 Gold!
« on: December 23, 2008, 04:23:19 am »
Dear all,
I have developed a data model and I would like to connect to an Access database via ODBC and generate the database tables directly.
I would like to do incremental updates/changes to the database directly from the model (must be kept in synch).
In release 834 of EA, support for Access 2007 is claimed. I am not sure if above feature as described is covered.
I can achieve this objective in Erwin but unfortunately, Erwin (3.5) does not read XMI.
kind regards
Segun
Re: Access database ODBC direct forward engineerin
« Reply #1 on: December 23, 2008, 09:23:20 am »
The support for Access 2007 was as an EA repository.
salayande
« Reply #2 on: December 23, 2008, 11:01:35 am »
A few application prototypes are built on Access databases.
I struggle to understand the role of EA in a prototyping development process or put simply, what is the point of capturing application requirements, designing data structures and then finally have to manually create the database schema in Access. For a start, traceability goes through the window and  the reuse of analyses artefacts is zero.
I think EA will add most value to a prototyping processes utilising Access by integrating (via ODBC ) for forward engineering.
Software products like WebRatio (www.webratio.com) and many more in the market suggests that Sparxsystems provide a capability that is almost dated but sorely missed.
Product management at Sparxsystems need to match the current profile of EA to that of these applications for better insight on end-user requirements.
kind regards
Segun
