Author Topic: Automating Diagram Commands  (Read 3757 times)
Tom C
« on: March 11, 2010, 05:58:59 am »
I am creating new diagrams through the automation interface. I have a couple of questions:
1) Is there a way to Open the Diagram once it is created through the automation interface?
2) Is there a way to set properties that are not specified in the Help such as the Diagram Property "Show Namespace"?
3) Is there a way to automate the Layout of the Diagram through the automation interface?
Thanks for any help you may be able to provide.
Re: Automating Diagram Commands
« Reply #1 on: March 11, 2010, 03:53:52 pm »
Tom,
1: Use Repository.OpenDiagram
2: Look in the Diagram.Style type properties. These properties contain magic strings ("setting1=value;setting2=value;...") that can be edited.
3: Look into the Project Interface, I think there are some methods there to autolayout a diagram.
Tom C
« Reply #2 on: March 12, 2010, 02:24:18 am »
Geert,
1) This worked great. Thanks.
2) There is a StyleEx and an ExtendedStyleEx property for the diagram, but they are both empty string after the diagram is created. I found a general Diagram option "Disable fully scoped object names" that I turned off, but this is a system wide option.
3) Thanks for pointing me to the Project Interface. I was able to use the LayoutDiagramEx method and this will give us a good start to formatting the diagram.
Thanks again for all of your help.
Tom
