Author Topic: Bulk modifications from within Element List  (Read 4686 times)
ChrisDr
« on: May 15, 2009, 04:00:21 pm »
to simplify, eg, requirements managment from within EA it would be very helpful to make bulk changes from within the Element List. E.g. if you have a bunch of requirements that you want to set from "Proposed" to "Approved" this works only one by one right now.
I could imagine something like multiple select items and then a right click on a column would bring up a selection of possible entries which you can select one from. This would only work for elements with drop-down lists in the Property fields, but that would be sufficient I guess.
Best regards,
Chris
Re: Bulk modifications from within Element List
« Reply #1 on: May 15, 2009, 05:20:38 pm »
There is a way to do bulk updates of the status and version field of all elements in a package:
  • right click on package
  • Package Control/Update Package Status...
Graham_Moir
« Reply #2 on: May 21, 2009, 10:57:01 pm »
Just tried this and it worked, although to have the changes reflected on open diagrams you have to reload them
ChrisDr
« Reply #3 on: June 09, 2009, 07:21:08 pm »
Hi!
Thanks for the information. Though not that fine granular as I'd like it, but with some moving around it does the job.
Chris
