Author Topic: Subversion Credentials  (Read 9740 times)
Uffe
« on: July 15, 2009, 03:51:19 am »
Hi!
When working with Subversion, EA assumes that the user logs into the repository using some other mechanism, and hangs during check-out if this hasn't been done.
The hang is obviously a bug, but the feature I'd like added is a way to enter your Subversion credentials for EA to supply to the server.
/Uffe
Re: Subversion Credentials
« Reply #1 on: July 15, 2009, 08:26:00 am »
Just so you know, the version control white paper specifies that you need to create the working directory before using EA.  This should require logging in.
Frank Horn
« Reply #2 on: July 15, 2009, 05:21:34 pm »
OK, but EA still hangs when e.g. you have changed your SVN password and forgot to log on before starting EA, which is definitely a bug.
Martin Terreni
  • Sorry, I can't write
« Reply #3 on: July 20, 2009, 12:25:27 am »
Also if you work with NT log in every time you change log in you need to log in to SVN. Why can EA change the credential (or at leats alert you theat the credentials are wrong)?
Recursion definition:
