Author Topic: Version 3.10 - Build 491 released  (Read 34898 times)
sparks
« on: May 24, 2002, 05:21:29 am »
Changes and Fixes for Build 491
- Added local setting to View/Options Code Generation page. Allows enable/disable capitalize of attribute name during Property generation
- Fixed bug that prevented constraints being added to elements, operations, attributes and links when new elements created from UML Profile stereotype
- Added Aggregation and Composition links to UML Profile.
- Fixed bug that prevented C# scope for attributes being generated correctly
- Fixed ordering and type bug in HTML generation of method parameters for HTML reports
- Added Files HREF to HTML generation - no modification is made to target - so HTTP or absolute address expected in Filename
- Added options to diagram dialog to show 'tag', 'requirement' and/or 'constraint' compartments in classes etc. on a per diagram basis
- Fixed bug in code generation that prevented attribute generation for Composition relationships
- Added HREF for all Hyperlink file types in diagrams when generating HTML Report
« Last Edit: May 24, 2002, 05:22:11 am by sparks »
