Author Topic: Displaying Notes in Attributes, not working  (Read 4085 times)
EricP
« on: July 30, 2009, 09:25:04 pm »
If I right click on a class diagram symbol and select Operations, I can then select an Operation and then select Behavior, make some notes about the behavior of the operation, check Show Behavior in Diagram, and click on Save, and the Behavior description will show up in the class diagram symbol under the behavior name.
THANK YOU for this... it has been a tremendous help in documenting my design in a way that some of the non-UML types on the project team can understand.
However... there doesn't appear to be any equivalent way to add Notes to Attributes.  If I right click on the symbol and select Attributes, I can add notes to each of my Attributes but can't make them appear on the symbol (or anywhere else on the diagram).
If there is a way to do this can you tell me how?  Otherwise, is it something you can add to an early new release?
Version of EA is 7.1 build 831.  As always, I'm willing to upgrade to the latest EA if it fixes this problem, though I really prefer not to change versions of my tools in the middle of a project unless there is a good reason to do it.
