Author Topic: set visibility per connector type  (Read 5666 times)
MatthiasH
« on: August 05, 2009, 10:04:31 pm »
I am creating a class diagram to represent the inheritance of a larger class hierarchy. EA draws all relations, like inheritance, association, dependency, etc.
This makes the diagram diffcult to read. Since the focus of the diagram is inheritance, I would like to set all connectors of other types  to invisible.
Currently I have to modify each individual connector, which is inefficient and bothersome.
It would be nice to extend the diagram properties to define which kind of connector should be visible or not.
This would also allow to quickly switch between different "views" of the same diagram.
Matthias
« Last Edit: August 05, 2009, 10:05:20 pm by mhildebrand »
Re: set visibility per connector type
« Reply #1 on: August 06, 2009, 02:30:09 am »
Agreed, and often mentioned.
Please make a Feature Request to Sparx. You can use the link near the bottom of any forum page. Perhaps if more of us do so this will reach sufficient priority.
MatthiasH
« Reply #2 on: August 06, 2009, 02:30:38 am »
...just found this one, which seems related in a way:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1241160674
Matthias
MatthiasH
« Reply #3 on: August 06, 2009, 02:35:59 am »
Done!
Matthias
« Reply #4 on: August 07, 2009, 10:05:49 am »
I'd support this, and
selection all/none, or by connector type.
See also
How to select and change all Lines Styles in a diagram
