Author Topic: Report generation from master document  (Read 3963 times)
Oli25
« on: March 18, 2010, 06:54:03 am »
Hi all,
I have master document with some detail documents. Each of them uses different rtf template. I need to generate documentation with using option tab... I would like to generate only elements with concrete selected status (e.g. status = proposed), but the final document still contains all elements (not only selected status). When I generate separate document with one of this template, final document contains only selected status on option tab.
Could you someone help me with them?
msherman
Re: Report generation from master document
« Reply #1 on: March 24, 2010, 01:05:40 am »
I am new to EA as well and am experiencing the same issue. Basically I have a diagram of classes that describe dependencies (satisfy) and when I generate the document I can select through the options tab to ignore any type of connection that is not this type (for example, I ignore composition and aggregation connections). However, when I include this template in the master document, option settings are ignored.
Is there any way to
msherman
« Reply #2 on: March 24, 2010, 01:55:50 am »
I just found the answer to my own problem. For others, you must right-click inside the template to open the context menu, then select File-> Document Options. Then you can identify the objects you want to exclude any time you use that document. Makes sense; it was just a buried setting.
Oli25
« Reply #3 on: March 24, 2010, 03:24:59 am »
Thank you,
you resolved my problem :-)
