Author Topic: Option to disable inline edit on packages  (Read 4602 times)
Stuart Trotter
« on: October 07, 2009, 03:01:31 am »
I really like the inline editing in EA, and it makes perfect sense with classes and most elements. However I use a lot of package diagrams for navigating the model and find it really irritating that a lot of the time when I double click the package it pops up the properties dialog for one of the contained elements.
Could we have a tool or diagram option to disable inline editing of packages? Or even an option to disable inline editing if the component is composite. I just want to drill down to the child diagram on double click.
I've had a number of our clients complain about this, so I know it's not just me being finnicky  ;)
Stuart
Re: Option to disable inline edit on packages
« Reply #1 on: October 07, 2009, 12:21:50 pm »
Hi Stuart,
In my view the WHOLE double-clicking technology needs serious refactoring.
You can't select a an unselectable item, but you can double click it and bring up the dialog - as you saw.
Then, the whole conflation of double-clicking brings up the properties OR hyperlinks - sucks.  Like you, I've had complaints from clients that they can't be sure what's going to happen when they double-click.
« Reply #2 on: October 07, 2009, 05:31:36 pm »
Personally I don't have a problem with that.
If there is the "infinity" sign (8 on its side) on the element then double-click will bring you to the linked diagram, otherwise it brings up the properties.
Not that hard is it?
Stuart Trotter
« Reply #3 on: October 07, 2009, 06:21:40 pm »
Hi Geert,
I don't have a problem with standard composite elements like structured activities or use cases, but packages where the package contents are shown can be problematic.
It's a small thing but when you use package diagrams as one of your main navigation tools it soon becomes irritating when half of your double clicks open a properties dialog for a contained element and you then have to close that dialog and try again to actually drill down.
Cheers,
Stuart
« Reply #4 on: October 07, 2009, 06:42:36 pm »
It is when not every type of object with a linked diagram - to which you wish to navigate to - gets a chain-links symbol (see recent bug reports).
BTW: it is chain-links and NOT an infinity symbol - to indicate the the fact there is a linked diagram.  Interestingly, neither chain links nor infinity, to me, has any relevance to the item being composite. ;)
Personally, I'd settle for (assuming every object with a linked diagram had the chain-links): If I double click the chain-links take me to the diagram, double-click anywhere else, open the properties dialog.
This allows the user a consistent experience (since if there's NO chain-links you ONLY get the dialog).
Also, it can be seamlessly extended to non-selectable items.  If I double-click on the chain-link, of an unselectable item, EA takes me to the diagram.  Otherwise nothing happens - just like with the keyboard.
