Author Topic: HTML Publishing - Control of Extent  (Read 4813 times)
wikitect
    • TRAK Community
« on: October 09, 2009, 08:42:57 pm »
HTML publishing is good at present but not very flexible. For starters it is predicated on publishing from a single root node. This causes 2 potential problems:-
    * Dependencies / things outside the root are lost in the documentation
    * It means anything not required to be published has to be moved to another root node outside the publishing hierarchy
It makes it very difficult to use sensibly on a large repository of models.
It would be nice to be able to:-
    * select the depth of publishing
    * be able to follow links outside the publishing root to a specified level (in the same way that Acrobat Professional does)
    * be able to specify a set of packages from which stuff is never published
Favourite epitaph: 'Under this sod lies another'
TRAK Framework https://sf.net/p/trak
MDG for TRAK https://sf.net/p/mdgfortrak
Re: HTML Publishing - Control of Extent
« Reply #1 on: October 09, 2009, 09:41:08 pm »
Good points and good suggestions!
You have submitted a formal feature request or Bug reports via the links at the bottom of the page, yes?
