Author Topic: Setting label visibility.  (Read 4931 times)
« on: December 02, 2009, 12:58:58 pm »
In the diagram properties dialogue it should be possible to set, for all connectors in the diagram,
the same visibility as can be done individually (and painstakingly) for each connector.
I'd like to see this on the Connector tab or the diagram properies dialogue.
« Last Edit: December 03, 2009, 07:18:24 am by skiwi »
Re: Setting label visibility.
« Reply #1 on: December 02, 2009, 01:10:29 pm »
The problem, Simon, is that (as far as I can tell at present - build 850) EA has no concept of selecting more than one arc on a diagram at a time.  You can select multiple vertexes, but not multiple arcs.
« Reply #2 on: December 03, 2009, 07:17:43 am »
Yes, I agree, arcs are 'second class citizens'.
Perhaps I am really asking for arcs to be treated much more the same as other objects, selection, formatting, movement, properties, methods in general.
« Reply #3 on: December 03, 2009, 09:23:43 am »
I see two requests in this thread. The OP was asking for improvements to the Diagram Properties dialog, and the next two posts are asking for multiple selection of connectors. Both good suggestions, but I'd go with the first one - much easier to implement.
« Last Edit: December 03, 2009, 09:26:34 am by KP »
« Reply #4 on: December 03, 2009, 07:20:49 pm »
Yes, but you'll need to allow partial selection.  Perhaps hook into the show visibility connector list so that we could pick which connectors to apply the settings to...
