Author Topic: Change order of Model Document attributes  (Read 7255 times)
marcelloh
« on: January 18, 2010, 11:19:08 pm »
If I use the project browser, I can see "inside a Model Document".
I see every package that I want to document. But it is impossible to change the order here  :-/.
I know you can do this via the attributes of a Model Document, but thats a lot more "user unfriendly" mouseclicks.
Dermot
Re: Change order of Model Document attributes
« Reply #1 on: January 19, 2010, 10:44:42 am »
The attributes are sortable via the Attributes View. The Project Browser arrows refer to packages/elements not sub-Elements. If you do want them sortable via theProject Browser it migh tbe best to lodge a Feature Request for this.
« Last Edit: January 19, 2010, 10:54:48 am by Dermot »
« Reply #2 on: January 19, 2010, 12:00:17 pm »
The attributes are sortable via the Attributes View. The Project Browser arrows refer to packages/elements not sub-Elements. If you do want them sortable via the Project Browser it might be best to lodge a Feature Request for this.
Well, Dermot, that was intuitively obvious...
The arrows should, therefore, be disabled when selecting a browser item that isn't movable via them...
RoyC
  • Read The Help!
« Reply #3 on: January 19, 2010, 12:27:21 pm »
As, indeed, they are.
Best Regards, Roy
« Reply #4 on: January 19, 2010, 01:50:41 pm »
OK, OK, so my monitor needs a good clean...  :-[
The two shades of green on my instance are rather subtle under the murk...  :'(
marcelloh
« Reply #5 on: January 19, 2010, 08:36:27 pm »
This is the "suggestions and request" part of a forum hosted and administrated by Sparx. If I make such a suggestions or request, I find it not so customer friendly to read if I would
"lodge a Feature Request" for it.
What was I doing in this forum then? Come on >:(
If something is in the wrong place, facilitate only one place where peaople can put stuff in, but if there are more places:
Fix it yourself! By our suggestions, you can improve your program,
which give you the free benefit of our ideas. Rember to honour the customer.
And no, i'm not p..off, i'm just dissappointed again.  :'(
« Reply #6 on: January 19, 2010, 10:21:51 pm »
[size=18]...[/size]
Get used to it...
One of my signatures is:
[size=10]Using EA in spite of EA, NOT because of it!TM[/size]
