Author Topic: EA_OnDiagramClose  (Read 6738 times)
SomersetGraham
EA_OnDiagramClose
« on: March 16, 2010, 09:26:00 pm »
I have declared this operation in my C# addin as
public void EA_OnDiagramClose(EA.Repository Repository, int DiagramID)
Now I thought this would get called when a diagram gets closed, but it does not.
Does anyone know if there is a problem with this method?
Graham
Using V12
Re: EA_OnDiagramClose
« Reply #1 on: March 16, 2010, 09:31:08 pm »
What version are you working on?
In my version (7.5.850) that event doesn't exist. (or at least is not documented in the help file)
SomersetGraham
« Reply #2 on: March 16, 2010, 09:32:06 pm »
AH - I have V8 installed, forgot to put it back to 7!
Using V12
SomersetGraham
« Reply #3 on: March 16, 2010, 09:38:39 pm »
Just reinstalled v7.5.850 and found it in the help!
SDK For Enterprise Architect
    Enterprise Architect Addin Model
        Broadcast Events
            EA_OnDiagramClose
Using V12
« Reply #4 on: March 16, 2010, 11:06:57 pm »
Graham,
Just looked at the release notes, and these events were added in version 8.
It's always possible that there might be a bug there, but make sure you have a clean install before trying to use it.
jkorman
« Reply #5 on: March 17, 2010, 02:03:06 am »
Gave it a try using EA 8.0.852 -
EA_OnDiagramOpen and EA_OnDiagramClose both fail to work.
I tried a couple of the other new events and they seem to work fine.
Jim
« Reply #6 on: March 17, 2010, 02:51:23 am »
better report it as a bug then so they can fix it before the next release.
« Reply #7 on: March 17, 2010, 09:10:52 am »
They are called EA_DiagramOpen & EA_DiagramClose in the source code, but I believe they will be changing before EA 8 goes official, probably to EA_OnPostDiagramOpen & EA_OnPostDiagramClose, so please be aware that it's all subject to change.
« Last Edit: March 17, 2010, 01:03:04 pm by KP »
jkorman
« Reply #8 on: April 01, 2010, 06:42:29 am »
Just an update. Just downloaded beta 3
The following functions work fine
public void EA_OnPostCloseDiagram(EA.Repository Repository, Int32 id)
and
public void EA_OnPostOpenDiagram(EA.Repository Repository, Int32 id)
(Above are for C#)
Jim
« Last Edit: April 04, 2010, 04:03:15 am by jkorman »
