Author Topic: Enterprise Architect and Sourcesafe configuration  (Read 4731 times)
Ramiro Garcia
« on: February 04, 2010, 02:27:40 am »
Hi, I need to know how make a configuration between enterprise architect and sourcesafe, I made something but when i want to make the check in appears an error.
RGM
salayande
  • I love YaBB 1 Gold!
Re: Enterprise Architect and Sourcesafe configurat
« Reply #1 on: February 23, 2010, 05:31:51 am »
I think that there are documents on using version control systems on the Sparxsystems web site. Reading trough may suggest a solution and if that does not help, please, contact user support directly.
« Reply #2 on: February 23, 2010, 06:32:53 pm »
Ramiro,
You might want to be a bit more specific on what you actually configured, and what the error is.
"made something" and "an error" doesn't really help that much.
Krayol
« Reply #3 on: February 24, 2010, 11:31:13 pm »
With one post and no replies in 2 weeks, I suspect Ramiro is long gone, but just for anyone else's benefit...
The paper http://www.sparxsystems.com/WhitePapers/Version_Control.pdf gives detailed instructions on using version control with EA.
Sourcesafe is an SCC compliant database so page 8 onwards relates to this system.  It should be fine!
Personally, I'd actually suggest changing from VSS to Subversion (for everything!) but then I've had enough bad VSS experiences for a lifetime! ;)
