Author Topic: MDG: How to stereotype a diagram?  (Read 10366 times)
« on: April 06, 2010, 09:47:07 pm »
Is it possible to stereotype a diagram within an MDG Technology?
I can create a new diagram type.  But I'd also like to set a stereotype.  Is it possible?
TIA,
Giu Platania
  • As Above so Below
    • Linkedin
Re: MDG: How to stereotype a diagram?
« Reply #1 on: June 25, 2019, 12:54:29 am »
I know this is a very old question, but I still trying to find an answer to that.
Anyone?
Giuseppe Platania
Enterprise Architect
Door Business Consulting
"As above so below, to accomplish the miracles of the One Thing" - Trismegistus
The above content reflects my own opinion and is not endorsed by Monthy Python
The above is NOT a reference to Monty Python
« Reply #2 on: June 25, 2019, 10:08:12 am »
No. The stereotype field on a diagram has no function.
What are you actually trying to achieve by setting the stereotype?
Giu Platania
  • As Above so Below
    • Linkedin
« Reply #3 on: June 25, 2019, 10:44:22 pm »
I could check the property using shapescript and set shapes
Giuseppe Platania
« Reply #4 on: June 25, 2019, 10:59:50 pm »
You can check the MDG type of your diagram in a shape script:
if(hasproperty("diagram.mdgtype", "MyMDG::DiagramType"))
Giu Platania
  • As Above so Below
    • Linkedin
« Reply #5 on: June 26, 2019, 04:43:45 am »
Thank you Geert
Giuseppe Platania
« Reply #6 on: July 11, 2019, 08:54:11 am »
Yes, we do that, but we also want to have variants to change the shapes (or behaviour) we display.  We have «Presentation» diagrams (which display "Stakeholder" versions of shapes - via smart shapescripts) and we have «Aggregation» diagrams that aggregate (automagically) sets of objects for our "landscape" diagrams.  So we add stereotypes as required.  However, I can see that if they truly are the type specified, then the stereotype needs to be added separately.
adepreter
« Reply #7 on: July 25, 2019, 12:42:37 am »
   if (hasproperty("diagram.stereotype", "Compact View"))
      defsize(100,15);
      rectangle(0,0,100,100);
      print("#name#");
   else if (hasproperty("diagram.stereotype", "Undecorated View"))
      defsize(105,20);
      addsubshape("paddingUndecoratedShape","n");
      addsubshape("nameUndecoratedShape","center");
      addsubshape("port","w");
   else
      defsize(90,70);
      addsubshape("padding","n");
      addsubshape("name","center");
adepreter
« Reply #8 on: July 25, 2019, 12:48:59 am »
Here is a resulting diagram in compact view mode (name of the diagram stereotype).
http://www.labnaf.one/guidance/index.html?guid=65903864-3A6F-4e6e-B08F-B2AE10211896
These diagrams are generated automatically following diagram templates that can also include auto legends.
Benefits
- All the diagrams are complete
- Saving a lot of time and money
- All the diagrams have a consistent layout
adepreter
« Reply #9 on: July 25, 2019, 12:55:43 am »
If you want to define it in the MDG, isn't simple to create a different diagram type and test the diagram type in the shape script?
« Reply #10 on: July 25, 2019, 08:35:51 am »
Yes, Alain,  that's the question I've been debating with myself at a conceptual/metamodel level.
What I'm after is to add a property to the diagram that I can test in the script, but diagrams are second class citizens and you can't.  So the stereotype is the only thing we have.
I want to be able to change the property at run time if necessary (which I can't -at least not so easily- if it's embedded in the type).  To your viewpoint discussion earlier today, it's the same View/ Viewpoint; just rendered differently.
