Author Topic: Diagram Filters: Filter on Tagged Value  (Read 7311 times)
Uffe
« on: April 07, 2010, 07:29:36 pm »
Hi!
Diagram Filters - sooo cool!
Now can I get the option to filter based on tag and value please?
Ie, tag named X contains/equals/etc value Y.
I'd accept a "hacky" way of entering it into the Diagram Filter dialog, eg "NAME=X,VAL=Y" in the dialog's Value column. Initially. ;)
I would also like filters for
  • Lock Status (Locked/Unlocked; disabled if security not enabled)
  • Baseline Version (contains/equals/etc)
  • Version Control Status (controlled/not controlled/checked-in/etc
Thanks!
/Uffe
mvinca
Re: Diagram Filters: Filter on Tagged Value
« Reply #1 on: May 24, 2010, 10:41:19 pm »
I agree that filtering on tag would be quite useful. We use tags in our requirements, of which there tend to be many.  ;)
Tim Twe
« Reply #2 on: May 25, 2010, 05:31:47 pm »
This would allow you to write scripts to analyze and tag part of your model and then visualize it appropriately.
Tim Twe
« Reply #3 on: May 26, 2010, 10:42:34 pm »
Why can I define a Model Search on TagValues but I cannot use the same query on Diagram Filters?
When I use "Add Filter" in a Model Search I have full flexibility however I do not have this same flexibility in the Diagram Filter.   It seems as though Diagram Filter even uses the same "Add Filter" dialog except it is fixed to constrain "Element" types.
Model Search is exactly the capability I need (and I believe everyone else also needs it) however Diagram Filter is locked on Element?
Tim Twe
« Reply #4 on: May 26, 2010, 10:47:52 pm »
When I am in the "Diagram Filter" and click "New Filter" and move to the filter configuration, If you press "Help" and see ththe "Search On" documentation it shows how you can search for different types of structures.
I am unable to change my filter to anything other than "Element".  Anyone have comments on this?
beginner
« Reply #5 on: May 27, 2010, 01:27:53 am »
EAUI
