Author Topic: Diagraming : hoizontal / vertical shifting  (Read 5636 times)
RainerQ
« on: September 01, 2010, 05:37:12 pm »
Hi
it would be nice to have the possibility to click some where in a diagram and then move the mouse for example down, which should result in moving all elements which are on the horizontal start line and below downwards.
Rational:
It often happens that space is needed somewhere on the diagram. Selecting all elements to move can be "some work" especially, if the diagram is larger than what you see on your screen.
Regards
Rainer
Re: Diagraming : hoizontal / vertical shifting
« Reply #1 on: September 01, 2010, 06:04:33 pm »
Rainer,
That feature is already available
Try Alt-drag on a diagram
RainerQ
« Reply #2 on: September 01, 2010, 06:42:59 pm »
Hi Geert,
thanks a lot for this hint. I wish I had known this before  ::)
How is this feature called officially? As it looks, I ran into a bug right away. I tried this feature on one of my mindemaps. The nodes have been dragged nicely, but the relationship line were not processed correctly. There fore I think it is time for a bug-report ;-)
Regards
Rainer
« Last Edit: September 01, 2010, 06:44:02 pm by RQ »
« Reply #3 on: September 01, 2010, 06:59:27 pm »
I have no idea what it's called, but this page in TFM describes it.
RainerQ
« Reply #4 on: September 01, 2010, 07:10:14 pm »
Hi Geert,
thanks for the link. So I will put my bug-report under the subject "[alt] + Move Elements In Diagram Sections".
Regards
Rainer
