Author Topic: Default label (read) direction  (Read 5235 times)
Raphael Parree
« on: September 02, 2010, 07:19:14 pm »
It would be great if you could enable the small triangle on an association label specifiying by default
Meaning the arrow (shaped as a black triangle)  used to indicate the reading-direction of the label, not the navigatebility arrow on the association itself).
Now on each label you need to right-click and specify the direction of the label
Thanks.,
Raphael
Takeshi K
    • Sparx Systems Japan
Re: Default label (read) direction
« Reply #1 on: September 03, 2010, 01:39:38 pm »
I (Sparx Japan) received the same request from a Japanese user and I made the Add-in to add the triangle automatically (from source to target).
It works fine, but nobody except the user seems to use the Add-in so I think there is no demand about the feature.
If the Add-in is helpful, I will post the Add-in to the Community site.
t-kouno
Raphael Parree
« Reply #2 on: September 03, 2010, 04:58:21 pm »
Thanks very much for your reply. Is there a way i could obtain that add-on? During modelling a semantic model (e.g, vocabulary etc) it is vital to understand the semantics of the connections between terms (facts). Without the direction arrow it becomes to difficult to understand the semantics.
I guess you even have the same problem in regular OO Domain and Conceptual Modelling.
If it is possible to share the add-on, could you provide me with an URL from which i can download it. Alternatively, we can exchange details via email.
Again, thanks very much
Takeshi K
« Reply #3 on: September 03, 2010, 05:43:38 pm »
Hi Raphael,
I have uploaded the Add-in to the Community site. I hope in near future everyone can download and use the Add-in.
If you find anything about the Add-in, please tell me (post to this Forum or add a comment in the Community site).
t-kouno
« Reply #4 on: September 03, 2010, 05:45:12 pm »
Raphael,
I think the reason why nobody is interested in this feature is because most of use don't use the name of the relation with a directional purpose.
I usually don't fill in the name of the relation, but instead give the AssociationEnds a meaningfull name.
In case of dependendies the direction is already set, so the direction of the label is already defined by the direction of the dependency.
