Author Topic: Java -> UML, reverse code engineering  (Read 3996 times)
Toowoxx
« on: December 02, 2010, 09:14:23 pm »
today i try to generate a UML-Diagramm from Java Code. The import goes great, but the EA make no associate between some classes. The Java settings are default.
Do you need some more information?
I hope you can help me.
Re: Java -> UML, reverse code engineering
« Reply #1 on: December 03, 2010, 08:09:02 am »
At a guess the relationships you expect to be created are from generic attributes.
The current version does not import relationships unless the type matches exactly, but this capability will be in a future version.
If this isn't the situation you are referring to, please clarify your request.
