Author Topic: Central Alignment  (Read 3967 times)
Steven
Central Alignment
« on: December 09, 2010, 12:12:18 am »
I have made some element and connected the elements. It is a scetch and I need to give it a clean and crisp look. So you select the elements and then choose Align Centers Vertical and all the elements are aligned ... except the connectors. They are now a zigzag from element to element.
Request: if I perform an Align Center can all the connectors between the selected elements also be aligned?
Re: Central Alignment
« Reply #1 on: December 09, 2010, 12:55:54 am »
Steven,
What would you do then when you have multiple connectors between two elements?
I think it would be better that you actually need to select the connectors as well to be aligned.
Steven
« Reply #2 on: December 09, 2010, 03:36:00 am »
Multiple connectors between two elements? Why would I want to do that?
« Reply #3 on: December 09, 2010, 01:28:47 pm »
Because if there exists more than one semantically unique relationship between the two elements, then you probably should represent it by the same number of connectors between the two elements...
