Author Topic: Enhance Execution Analyzer EA 8.0 Corp(ASP.NET)  (Read 3934 times)
eeidfn
« on: January 25, 2011, 04:19:18 pm »
Please enhance this feature:
  • 1) Enhance the "Class markup" featue with a new marker type for "Start Stop Recorder".  Similar to the "Record Function" marker type.  Then it becomes easy to mark an entire class library or DLL.
With the Record Function marker type, the sequences are recorded all together in one set.  When I use the Start/Stop marker type manually, the sequences are recorded in separate sets.  I want this to continue so that I can choose which continuous subset of sequence sets to include in a sequence diagram. :)
2) Enhance Generate Sequence Diagram feature so that a diagram can be generated from a subset of the history, not all.
OR
3) Enhance the Recording History so that selected sequence sets in the history can be cleared as opposed to all.
4) Could not get the lifeline to look different based on toggling "Assume message returns" and "GarbageCollect" check boxes. But toggling "Show Sequence Numbering" worked.  This is under Tool -> Options sub menu -> Sequence page.
5) Could not hide namespace in sequence diagrams by unchecking "Show Namespace" check box.  I was told by admin that he did not set/unset anything specifically. Using EA Corporate Edition.
[/list]
Thank you
[timestamp=1295932548]
