Author Topic: Find and delete orphanded items  (Read 17738 times)
karlwg
« on: March 05, 2011, 01:26:21 am »
I noticed, that elements can stay within the Project Browser even if they were deleted from all diagrams.
Is there a way to find (and then delete) such orphaned requirements?
Kind regards
Karl
Re: Find and delete orphanded items
« Reply #1 on: March 05, 2011, 03:30:46 am »
Ctrl-F
Find Orphans
select all
Ctrl-Del
karlwg
« Reply #2 on: March 07, 2011, 08:04:59 pm »
Thank you very much, this is, what I was looking for!
Graham_Moir
« Reply #3 on: March 08, 2011, 12:34:46 am »
And just for info, a simple deletion on a diagram,  i.e. pressing the delete key when an element is selected will never delete the element from the model/project browser.    You have to use control-delete to achieve that.
hfrmobile
« Reply #4 on: November 16, 2016, 11:37:36 pm »
Was predefined search "Find Orphans" removed in EA13?
« Reply #5 on: November 16, 2016, 11:39:51 pm »
I guess you need to search for it. Didn't you know the Easter bunny has its main residence on planet Sparx?
Honestly, I don't know the answer  :-\
Diagram Searches/the first on the list
hfrmobile
« Reply #6 on: November 16, 2016, 11:57:46 pm »
Thanks a lot!
Looks like documentation is not up-2-date  ;)
« Reply #7 on: November 17, 2016, 12:41:40 pm »
Umm, that is not actually true.
There are things, that when deleted on a diagram, disappear into the great bit bucket in the sky, please be very careful giving advice like this.
For example if you delete an attribute from a class it is gone (but not a column from a table, or an attribute from a model document)
RoyC
  • Read The Help!
« Reply #8 on: November 17, 2016, 02:26:23 pm »
It is also not a good idea to delete everything on the Find Orphans report without knowing exactly why it is an orphan. As several of you have pointed out many times, diagrams are just a human-support mechanism to help you visualize an aspect of your model, and you could - if you felt so inclined - develop part or all of your model without using diagrams at all.
@hfrmobile - what documentation are you referring to? As far as I can see, the release 13 Help is up to date; where did you find the not-updated material?
Best Regards, Roy
Graham_Moir
« Reply #9 on: November 17, 2016, 09:40:41 pm »
Isn't an orphan an element that has zero relationships rather than an element that isn't on a diagram?
Also, Skiwi, point taken,  my comment was slightly ambiguous, but the main thrust of what I said related to elements and that still holds true I believe...   "pressing the delete key when an element is selected will never delete the element from the model/project browser.    You have to use control-delete to achieve that."
« Reply #10 on: November 17, 2016, 11:35:33 pm »
For those who want to see the "real ophans", I wrote an SQL query a while ago that return the elements that are really not used anywhere.
See Searching for REAL orphans in Enterprise Architect
« Reply #11 on: November 18, 2016, 06:09:49 am »
Graham, I think it depends. An orphan is someone/something without relations. I guess one can argue that an element not showing on a diagram is also "unrelated". However, there should be lists for both orphan types (maybe Geert's script does address this).
« Reply #12 on: November 18, 2016, 10:51:47 am »
Don't agree.  It the wrong use of the word "orphan".  The existence of an item on a diagram and or the browser is a matter of choice, even if inadvertent.  That's not to say there shouldn't be a means of finding them -as they represent anomalies within the model.
In addition, I believe EA treats items which have no package (for example, the package has been deleted, but the package reference remains) as "orphans".  I don't think that's correct, they are just logical inconsistencies - which are rectified by the Project Integrity Checker.
