Author Topic: ArchiMate icons for product and object - line wrap  (Read 4135 times)
David G
« on: June 16, 2011, 11:07:03 pm »
As an ArchiMate user, I would like ArchiMate product icons and ArchiMate object icons to handle multi-line name/title strings gracefully.
Currently, the rendering does not wrap name/title text correctly within the bounding text box:
The other "information" / "passive structure" icons are OK:
The Open Group documentation for the data object in ArchiMate provides the following example, which wraps the text inside the whole box (including the top dividing line):
...but then a moment later it gives the following example that has all the text within the lower "partition":
Either approach would work well in practice I think:
FWIW, the Archi modelling tool takes the "all in the lower partition" approach (but I'm not saying this is the right way!):
Thelonius has previously raised the same point about multi-line wrapping in the Automation forum, so could you consider this request to have two votes already?
« Last Edit: June 17, 2011, 02:39:14 am by dgbl »
David G
Re: ArchiMate icons for product and object - line
« Reply #1 on: June 17, 2011, 12:31:49 am »
The Grouping construct has the same problem:
