Author Topic: State Transitions  (Read 3933 times)
sbaldrick
State Transitions
« on: September 16, 2011, 08:53:15 am »
In the Transition Properties dialogue window, one may specify the effect as behavior and select that behavior from a list of class operations.
In the dialogue window there is room for selection of several behaviors, yet each time I select another behavior it replaces the existing behavior instead of adding to it.
It is normal for a state transition to trigger several operations. It should be possible to select several behaviors describing those operations.
« Last Edit: September 16, 2011, 08:53:56 am by MundayL »
Re: State Transitions
« Reply #1 on: September 16, 2011, 05:43:51 pm »
Leslie,
I believe it is indeed a UML restriction that a transition can have at most one behavior as effect.
So I guess EA is just (trying) to be UML compliant. (an Operation is not a Behavior, so they are still wrong here)
sbaldrick
« Reply #2 on: September 17, 2011, 02:30:29 am »
Behavior/Operation - I may have mixed up the terms a bit.
As an example, a state transition may cause many triggers to be fired in addition to performing 1 (or more) operations within the current object.
The easy workaround is to create an operation that performs the complete behavior of the transition, but this seems a little awkward, and doesn't help clarify the requirements.
